Scilab Gateway: Does the target computer need Scilab installed?
Maybe a dumb question, but if I use Scilab Script nodes in my application, will the target need to have Scilab installed as well after deployment?
Because after this article, I thought all I would need would be to copy ScriptScilab.dll in Runtime folder.
Did I misunderstand?
Is it the same for MATLAB?
Thanks!
(2,965 Views)
Accepted by DCanQAlias
Hi DCanQAlias,
Yes, you will need to have Scilab installed according to the instructions in the last section here:
https://www.ni.com/en/support/documentation/supplemental/06/connecting-labview-with-scilab-enterpris...
This is the same requirement for the MATLAB® script node.
MATLAB® is a registered trademark of The MathWorks, Inc.
Joel I.
Applications Engineer
(2,922 Views)
Hi Joel,
OK, that's what I feared.
Thanks for the confirmation!
(2,909 Views)
