Scilab Gateway: Does the target computer need Scilab installed?
Maybe a dumb question, but if I use Scilab Script nodes in my application, will the target need to have Scilab installed as well after deployment?
Because after this article, I thought all I would need would be to copy ScriptScilab.dll in Runtime folder.
Did I misunderstand?
Is it the same for MATLAB?
Thanks!
(2,990 Views)
Accepted by topic author DCanQAlias
Hi DCanQAlias,
Yes, you will need to have Scilab installed according to the instructions in the last section here:
https://www.ni.com/en/support/documentation/supplemental/06/connecting-labview-with-scilab-enterpris...
This is the same requirement for the MATLAB® script node.
MATLAB® is a registered trademark of The MathWorks, Inc.
Joel I.
(2,947 Views)
Hi Joel,
OK, that's what I feared.
Thanks for the confirmation!
(2,934 Views)
