Scripting: Show node/structure/object in BD
Clicking a row in conventional list of Search Results opens BD of corresponding VI and brings the found item in area of view.
Is there a simple way to do the same in LabVIEW scripting? I need to show a BD object to user.
Of course, I can implement traversing through all BD structures, calculating relative positions, etc. etc. However it could be discovering of a wheel.
Thank you
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
(2,864 Views)
Accepted by _Y_
The Object Highlight method using an invoke node should do what you want.
(2,799 Views)
Thank you, it works (LV2016 32bit)
(2,793 Views)
