Search Indices in 2D Array in a Range
Probably I am doing something wrong...
Message 11 of 16
(1,413 Views)
Another option would be to reshapae to a 1D array and use search-1D-array in the boolean output of the "in range and coerce" function. Here's an old example.
Message 12 of 16
(1,409 Views)
The outer for loop tunnel should be concatenating instead of indexing.  I would move the IR&C function inside the for loops and autoindex the original array.  No need to create the intermediate boolean array.
Message 13 of 16
(1,403 Views)
Hi Ivan,
as others noted you have to change the output tunnel mode.
- You also placed the Abs() function in the wrong place.
- You didn't use the snippet I provided…
Message 14 of 16
(1,392 Views)
Accepted by Ivan899
I have been thinking that the row and column indexes are the i values of the two loops, so why not present it that way?  And Thanks to Darin for pointing out that moving IR&C inside the loop simplifies things. So now I create an array of cluster of row, column indexes.
Lynn
Message 15 of 16
(1,385 Views)
Thanks to you all!  You`ve helped me so much!
Message 16 of 16
(1,374 Views)
