Searching for Enum text mangles the Enum selection
I spoke with LabBEAN directly, but I wanted to make sure that this info was available on the forums as well. The fix for this bug will be included in an upcoming LabVIEW 2011 SP1 patch. When the patch is released, it will be available for download at ni.com/downloads and through the NI Update Service.
Thanks again for bringing this issue to our attention and sorry for the inconvenience that it may have caused!
Matt
NI Community Team
Message 11 of 17
(1,307 Views)
Accepted by LabBEAN
It appears this has been patched in LV 2011 SP1 f2.
Message 12 of 17
(1,284 Views)
Thanks for the heads up, Ravens.
Confirmed by the example I posted originally, the bug appears to be fixed in LabVIEW 2011 SP1 f2
The new patch has not posted on ni.com/downloads yet, but it is available through the link above or through LabVIEW » Help » Check for Updates.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 13 of 17
(1,273 Views)
CAR 354380, which addresses the problem discussed in this thread, is fixed in patch 2011 SP1 f2. You can obtain the patch via NI Update Service (by weekly notification or by running NI Update Service) or download from NI.com. The Knowledge Base (KB) document for this patch lists other problems that were also addressed in this patch.
Roy Faltesek
Senior Group Manager
LabVIEW R&D
Message 14 of 17
(1,245 Views)
I would like to know how this search is supposed to work.
I would like to be able to find enums that contain a certain string as one of the items. Is this possible? (How?)
 - les
Message 15 of 17
(1,194 Views)
Message 16 of 17
(1,186 Views)
...and place a check in the 'Hidden' box.
Sometimes I don't understand the meaning of the options correctly, and wonder why they don't work. 🙂
Thanks.
 - les
Message 17 of 17
(1,175 Views)
