08-15-2012 12:30 PM
I spoke with LabBEAN directly, but I wanted to make sure that this info was available on the forums as well. The fix for this bug will be included in an upcoming LabVIEW 2011 SP1 patch. When the patch is released, it will be available for download at ni.com/downloads and through the NI Update Service.
Thanks again for bringing this issue to our attention and sorry for the inconvenience that it may have caused!
08-24-2012 10:37 PM
08-25-2012 07:23 PM
Thanks for the heads up, Ravens.
Confirmed by the example I posted originally, the bug appears to be fixed in LabVIEW 2011 SP1 f2
The new patch has not posted on ni.com/downloads yet, but it is available through the link above or through LabVIEW » Help » Check for Updates.
08-27-2012 09:57 AM
CAR 354380, which addresses the problem discussed in this thread, is fixed in patch 2011 SP1 f2. You can obtain the patch via NI Update Service (by weekly notification or by running NI Update Service) or download from NI.com. The Knowledge Base (KB) document for this patch lists other problems that were also addressed in this patch.
Roy Faltesek
Senior Group Manager
LabVIEW R&D
01-28-2013 01:10 PM
I would like to know how this search is supposed to work.
I would like to be able to find enums that contain a certain string as one of the items. Is this possible? (How?)
- les
01-28-2013 01:21 PM
01-28-2013 01:56 PM
...and place a check in the 'Hidden' box.
Sometimes I don't understand the meaning of the options correctly, and wonder why they don't work. 🙂
Thanks.
- les
