Select the value inside numeric control after clicking on it (perform double click after one click)
Hi
I want to speed up the process of filling couple numeric controls by user.
When he click on the control (let's say he doesn't know about tabbing) I want the value inside to be selected, so that he doesn't have to delete value inside to enter a new one.
What should I put inside Mouse Down event to perform this selection?
I couldn't find selection in invoke node. Is there something like that?
Or using AutoIt to perform another click is the only way to go?
(3,333 Views)
Accepted by siadajpan
Use the MouseDown? filter event and wire a True to the Discard data node on the right side.  Inside, wire a True to the KeyFocus property of that control.
(3,289 Views)
