Selecting help causes seriouse crash of labview
After upgrading to Labview 7.1.1 help system not functional.
As soon as you try to open help on vi  system crashes.
Message 1 of 10
(3,677 Views)
Think I found problem lvhelp.chm appears to be corrupt will not open, other .chm files work.. ? any place where I can download a copy?? I am not in office for next week to get to my CD's...
Message 2 of 10
(3,678 Views)
Hi Harold,
Please see if the following KB helps:
Why Can't I Open Help on Windows NT in LabVIEW?
Ankita
Message 3 of 10
(3,661 Views)
Hi
thank you but i did find link, that is how I know it is only the lvhelp.chm file that is corrupt, all other help files even others from LabView runs..
Harold
Message 4 of 10
(3,649 Views)
hi there
here's a copy of my lvhelp-files (LabVIEW 7.1)
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 5 of 10
(3,646 Views)
Hi
Thank U    but
Winzip complains file is corrupt size downloaded is 1030 and not 1320 as on posting. Have tried different was downloading normal, download accelerator differnet directories, am I going mad or is alsheimers setting in...?
Harold
Message 6 of 10
(3,643 Views)
hi there
see ftp://ftp.ni.com/incoming/ and download lvhelp.chm and lvhelp.chw. i first wanted to post both files, but the extensions are not allowed, so i needed to rename the files. and the file sizes are more then 3 MB, so that's too much.
the files on the ftp-server will be deleted in 24Hrs!
Best regards
chris
Message 7 of 10
(3,635 Views)
Hi
Thank you.
Message 8 of 10
(3,628 Views)
Hi
This does not make sense if I run the file from any other directory than programfiles\labview\help it works but when I copy the file to final destination directory it still causes the system to crash. Do I need to register or unregister....
All other chm files in help subdirectory can be openend....
Message 9 of 10
(3,617 Views)
I found the following freeware software that identified and fixed my helpfile problem's
http://helpware.net/downloads/index.htm#MJs    MJ's Help Diagnostics
It was one of the help file .dlls that was not registered (how this happend is ...?)
Message 10 of 10
(3,569 Views)
