Separating multiple waveforms in waveform graph
Is there a way to separate multiple waveforms on a waveform graph?  I would like to display 6 waveforms with the same time frame, but I want to spread them out so they aren't on top of each other.  Can this be done?
Message 1 of 10
(4,364 Views)
you can create a separate Y axis for each plot...
Message 2 of 10
(4,359 Views)
You can also choose Stack Plots on the right click menu.
Message 3 of 10
(4,331 Views)
Is that in the Properties page?  I can't find anything that lets me do that.
Message 4 of 10
(4,317 Views)
Hi John,
This option is only available for charts IMHO.
The OP asked for a graph…
Message 6 of 10
(4,315 Views)
I found that under the Appearance tab, but it is grayed out.  It looks like that is not an option for a waveform graph.
Message 5 of 10
(4,315 Views)
Accepted by rgl0886
It's not pretty, but you can iterate over the array and modify each waveform to provide a y-offset.  use "Get Waveform Components" to get the y-array and add a number to the y-array.  build back into waveforms using "Build Waveform". make sure this modified data goes only to the graph (you don't want to propagating to any data analysis or file saves).
Message 7 of 10
(4,303 Views)
Hi pj,
When you use an autoindexing FOR loop you don't need that BuildArray at the end.
You can use ADD directly with waveforms, so also no need for GetWfmComponents!
Message 8 of 10
(4,298 Views)
@GerdW wrote:
Hi John,
You are correct. I hardly ever use graphs (and don't generally use this option for charts) so I had not noticed this. Thanks.
Message 9 of 10
(4,294 Views)
I tried your suggestion, and you're right on both counts:  It does work and it isn't pretty.😄  I decided to simply put multiple waveform graphs into the display and split things out that way.  With careful placement it all looks pretty good to the operator.  Thanks for your suggestion though.  It helps me understand Labview a little more each time I try something.
Message 10 of 10
(4,229 Views)
