overwrite tdms file property names and values
I need to overwrite  property names and values for a tdms file. Using "TDMS set property" function, new property are appended and not overwritten. How can I solve this?
Arianna
Message 1 of 23
(2,947 Views)
I need to overwrite property names and values of a tdms file. Using "TDMS set property" new property are appended. Is there a way to implement this?
Thanks 🙂
Message 2 of 23
(2,884 Views)
Arianna
First of all, why have you asked the same question twice?
Next, can you share an example code that you are having problems with? The TDMS set property function works fine to overwrite the property for me, so perhaps you are doing something incorrectly. This would be much easier to find if you attached your vi (or a minimal vi that exhibits the problem).
Message 3 of 23
(2,929 Views)
one detail to be carefull about is "property of what"
pay attention to which combination of group & channel you link your properties to.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 4 of 23
(2,910 Views)
sorry for the double question, I had some problem with the spam report. I attached the vi now. Thank for the fast response
Message 5 of 23
(2,906 Views)
Can you save this to a previous version? I have not yet upgraded to LabVIEW 2020.
Message 6 of 23
(2,900 Views)
I need to modify property only at data set level.
Message 7 of 23
(2,898 Views)
Here the vi 19.00 version. Thanks
Message 8 of 23
(2,891 Views)
Could you also attach an example tdms file and populate your controls with default data?
Message 9 of 23
(2,882 Views)
Here the file, thanks
Message 10 of 23
(2,866 Views)
