overwrite tdms file property names and values
Thank you very much for all your time. Can you explain me the last thing, please? Which is the purpouse of the last fto cycle with "TDMS Delete Data" function?
Message 21 of 23
(613 Views)
I assumed that you wanted a TDMS file that had the same structure (groups/channels) as the original TDMS but without the data. If this is not the case then you can omit that part.
Message 22 of 23
(605 Views)
Thank so much for your time 🙂
Message 23 of 23
(575 Views)
