Serial Communication Problem
You haven't shown any screenshots that show you sending a termination character after sending the $.
All you are sending is the dollar sign.  You haven't sent either a carriage return, or line feed, or carriage return and linefeed which is what happens when you hit enter in hyperterminal
Message 11 of 13
(1,825 Views)
Sorry actually i forget to share the block diagram. In block diagram i have concatenated the the line feed and end of line string constant.
Message 12 of 13
(1,812 Views)
Accepted by Sreekumar87
Thanks to all..
The problem resolved.. I have tried to send one by one character using visa instead of the full string.. now its working fine.. In normal RS232 terminal its accepting full string but in USB virtual COM port it is accepting one by one character only, it may be Driver side disability.
Once again thanks to all..
Sree
Message 13 of 13
(1,807 Views)
