Serial Port communication with PIC
Dear All.
I am interfacing the labVIEW to a eeprom through a PIC controller,in which i need to user entry data to store in a location of EEPROM,according to my requirement i did the pic programming and it working fine with hyperterminal,at the same time i need to do with a labVIEW by using serial port communication VISA,but when i did i am getting one warning in 1073676294 which can ignore but i am not able to write the user data to EEPROM through labview but i can do it from hyperterminal,please any one help me on this.
Raikar A G
Message 1 of 8
(5,964 Views)
Accepted by Raikar
I have been interfacing to PICs for a while, and the example you have build from was the same I used. First, move all the INITILIZATION outside the loop. No need to re-init the COMM PORT every 750ms.  Inside the example code there is a 500ms wait between the WRITE and the READ (it is hard coded at the moment, you did not bring it out on the ICON).  So total time is the loop's 750ms plus the 500ms wait (plus comms traffic), FYI.
You are not using a carraige return (13) or a LINE FEED (10) as a termination. You are using a SO(14). Unless you are triggering on a an ASCII 14 in the PIC, the PIC will never see the "end of the command string" to parse it out. I attached a good (IMO) init routine that I re-use on all my PIC projects, take a look.
I use the Mikroelectronica MikroCPRO compilers, and posted a full UART interface (triggers on a CR(13) ) on their LIBSTOCK site if you want to take a look at the PIC side of my work.
http://www.libstock.com/projects/view/250/rs232-interrupt-driven-command-based-interface
Steve
Message 2 of 8
(5,921 Views)
Dear Sir.
Thanks a lot for your valuable suggesting,I got the it now...
Raikar A G
Message 3 of 8
(5,907 Views)
Glad it helped! Pls leave me a KUDO - I hove NONE yet 🙂
Message 4 of 8
(5,897 Views)
Hey Steven8R,
Any chance you could send me a snippet of your example code above? I am working with LabVIEW 2011 so I cannot open the VIs. I want to avoid having to download and install LabVIEW 2012.
thanks,
-Serge
Certified LabVIEW Developer
Message 5 of 8
(5,448 Views)
Then use the Version Conversion board.
Message 6 of 8
(5,434 Views)
I see. Thanks Dennis 🙂
Message 7 of 8
(5,421 Views)
Conversion was done here: http://forums.ni.com/t5/Version-Conversion/Convert-LV2012-VIs-to-LV2011/m-p/3162034#U3162034
Message 8 of 8
(5,411 Views)
