Serial data
irrespective of the com port we select it shows the error so could u guide us in the driver that is required... i have posted the screenshot of the error that pops up when we run it...
Message 11 of 18
(3,975 Views)
In that case have you installed all the drivers required by the hardware?
Message 12 of 18
(3,967 Views)
Message 13 of 18
(3,965 Views)
If you would start tool I suggested, you would see the message on start:
"It seems VISA is not installed" 😄
So, install VISA driver.
Message 14 of 18
(3,948 Views)
we thanku for suggesting the drivers.. at present it is running without error.. bt after sending the data through the software RS232 analyzer it is not being displayed in the output.
wat should we do?
Message 15 of 18
(3,923 Views)
What is your sent data?
Message 16 of 18
(3,912 Views)
we where just chekin by transmitting ASCII values through RS232.. but it was not displaying the same.................
Message 17 of 18
(3,904 Views)
Make sure you can loop data when using the "Basic Serial Write and Read" Example. Short pin 2 and 3 on your serial port, and run the example with "None" selected as flow control.
If that example is not working I would recheck drivers and connections.
Message 18 of 18
(3,882 Views)
