Serial port sending 20 instead of 00
I am having an issue sending a Hex string out to my com port.  Any string I send that has bytes of 00 get converted into 20.  This seems like it should be a simple problem.... can anyone help?
Andrew
(3,096 Views)
You should post example code so that we can see exactly what's going on, but my guess is that your string doesn't have a null char (0) and it does have a space char (20h). The easiest way of telling is right clicking the string control and changing it to hex display.
___________________
Try to take over the world!
(3,091 Views)
The string control was set to Hex before I entered the data in.  Here is a picture of the code.  (I have not written in anything for error handling or any checking to see if the message was read, at this point I am just taking a known value written to the comm port by other code and trying to see if it will work in labview) This is all directly written to a TI MSP 430.
Message Edited by labstew on 04-10-2008 02:27 PM
(3,086 Views)
There is a property that can be accesses via property node called Discard NUL character.  Make sure this is set to FALSE.
Randall Pursley
(3,057 Views)
I checked this and it was set to false by default.  I hardwired in a false constant just to be sure and tried it.  Still having the issue.
Andrew
(3,042 Views)
I got the code working, the issue was the allow nulls combined with a typo after I changed this :(.
Thanks for the help.
Andrew
(3,025 Views)
