Set cluster's control value in subpanel
Hi
Is there a way to set the control value of a cluster in a subpanel?
I enclose my vis in LV8.0
Charly
It's always sunny in California! Certified LabVIEW Associate Developer!
(4,224 Views)
You can use a control reference to set the value property, or pass a value to its terminal. In short all the typical mechanisms. What exactly is the issue?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,221 Views)
Hi Mike,
To pass a value to a control which is in a subpanel I usually use the Invoke Method Control Value:Set. It requires the refnum of the subpanel, the value of the control and the name of the control.
When the control is into a cluster the name of the control is not found anymore. I don't see how I can access it. Do you have an example or a link for me?
Charly
(4,214 Views)
Accepted by CharlyStardust
If you have a reference to the VI being put into the subpanel (which you must have or it wouldn't be in the subpanel, right?) you can use that to get a reference to the VI's front panel. This in turn will let you get an array of references to all the controls and indicators on the subpanel VI's front panel. Go through this array looking at the label:text property for each reference in the array until you find the one for the control that is the cluster.
Now, use the To More Specific Class function to cast the cluster's generic control reference to a cluster reference. You can use it to get an array of all the controls inside the cluster. Now go through this array looking at the label:text property for each reference in the array until you find the one for the control thatyou want to set and there you are...
Mike...
LabVIEW Champion
(4,209 Views)
Ok I see what you mean. Do you think you can access directly to the control in the cluster with just a name? something like ClusterName.Ctrl or ClusterName:Ctrl
Thank you
Charly
(4,200 Views)
No, you have to dissect the data structures like I described.
Mike...
LabVIEW Champion
(4,198 Views)
Hi Mike,
can you show out the sample? b'cos i try to find of reference of the array but can't or do you have any sample regarding for this things?
Sorry for trouble you.
William Lee
(3,954 Views)
