Setting Specific Thermocouple Type in Block Diagram
Hi all,
I have an example VI that I am playing with. I would like to remove the thermocouple selector on the front screen and just set the input to the DAQmx block as a K type as I only have K types. How would I do this?
(3,282 Views)
Just move the enum to the block diagram (drag) to create an enum constant and set it to K type.  You can then delete your fp object.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(3,275 Views)
Accepted by bronco9588
Or simply right click on the terminal and select 'Change to Constant'.
You can learn a lot by right clicking on objects and viewing the options.
(3,268 Views)
Yes, that too, with fewer mouse clicks.
(3,263 Views)
Hi bronco,
  I am learing to read themocouple measurement also. Is it possible for you to post the subVI also so I can run it? Thanks a lot.
(3,208 Views)
