Shapes on the same graph
thats helped alot, thank you so much
Message 11 of 31
(1,125 Views)
do you know of anyway to put a delay on the triangle and rectangle so that the plots are shown individually, so it looks like its drawing the shape not just the full shape appearing staright away?
Message 12 of 31
(1,120 Views)
I made you a random shape function. You can adjust it like you want.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 13 of 31
(1,117 Views)
You want it to show it in steps. Like you draw it with a pencil?
Message 14 of 31
(1,116 Views)
I want to be draw the rectangle and/or triangle from the the first part of the plot the the next plot on the graph to the next etc. Does that make sense?
http://www.youtube.com/watch?v=gPfFaIPWJDg like the vides but obviously without the pencil
Message 15 of 31
(1,106 Views)
It is possible, but very time consuming.
So I hope you like this one.
I made a draw for the square.
probably not programmed optimal
Message 16 of 31
(1,095 Views)
thats helped so much. what would you recomend to someone who has just recently started to use Labview? ie tutorials and stuff like that
Message 17 of 31
(1,087 Views)
Good to hear that!
There are some tutorials:
Unit 2
Unit 3
Unit 4
Note: unit 0 and 1 won't be necessary, maybe 2 neither
But you'll find that out yourself Smiley Happy
And way more to be found here and youtube ofcourse.
And then after getting a bit better. Try looking at code on the forums.
Try to solve other people's problems, try to find out why certain solutions work or even try to make them better.
Start by the code you have now, what is everything doing and why.
Message 18 of 31
(1,081 Views)
Btw, a tip for the draw function. The graphs supports double (DBL). This way you can reduce the stepsize to make it look smoother, decreasing the wait will also help alot.
But becareful if you change it to DBL you'll need to change the comparsion, from = to > or <.
Because doubles aren't that great for comparison, better described here.
Message 19 of 31
(1,077 Views)
ok ill look into that 🙂  i only have one more question now with the code, when i try to draw the rectangle i cant seem to make it into a rectangle its more of a square. i don't know if im just missing something or not but i cant seem to change it. any ideas?
Message 20 of 31
(1,075 Views)
