Shared Network Variable not in Distributed System Manager
I am experiencing this with LocalHost.   I have 2 computers A,B.  On A I can read a SNV created/shared from B.  However, I need to use a SNV on A to A (I am not sure why, I inherited this project and it is not commented at all).  So I create it and I see it on my D:\\ drive.  However, when I go to NI DIstributed System Manager, there is no library under localhost.  So I write to it in one VI and call it in another, and I get "DataSocketRead in VI" with code 56.  Not sure why I cannot get it is the manager.
I ahev attached the library in case something is wrong there.
(4,842 Views)
Have you created a LabVIEW Project, put the Shared Variable Library in the Project, then run some code that uses the Shared Variable?  I'm pretty sure that just having the Library copied to Computer A won't make it show up in A's DSM -- I'd think you would actually need to use it on A for it to show up.  Once you've done that, however, it should persist (my machine has several Libraries still hanging around from tests and abandoned Projects ...).
(4,838 Views)
Yes it is in the project
(4,834 Views)
Accepted by jmaslek
Have you right clicked and deployed the shared variable library?
If this is a built executable in properties of the bulder you need to check to deploy shared variables.
Glad to answer questions. Thanks for any KUDOS or marked solutions 😉
(4,827 Views)
That was it.  Thanks!
(4,823 Views)
You're very welcome.
(4,798 Views)
