Sick lms 100
Hi Samira,
what you found applies only if you communicate with external code, like a DLL built in C or C++ or something else.
It´s not an issue with TCP.
But your lucky 🙂 I´ve found a project someone did here in our office with the same laser scanner, and I can share the code.
It is well organized, but as far as I can see not well documented... 😞
But still you can look up how the communication is done, and it should also work right out of the box.
Give it a shot.
best
Marco
Message 11 of 16
(2,916 Views)
Hello Marco,
Thanks a lot but honestly  i already have these files! but on my pc no outut is showed. I just get the msg:
Error 1 occurred at TCP Write in LMS100_Request.vi->LMS100_ReadStatus.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
By running my own code(attached) i face error 56.  😞
Samira
Message 12 of 16
(2,912 Views)
Hello Alexander,
I have changed a VI, saved(by mistake) and closed it, but yet not shut down. Can i recover the file somehow?
Samira
Message 13 of 16
(2,892 Views)
Hello Marco,
With the attached code, i can read continuous data from an LMS100 laser scanner connected to CRIO 9024. But I have no idea what these LMS answers I get mean(attached as PDF file). In addition i wanna see what the laser scanner views on a gragh, but I have no idea what i should do. Reading the LMS 100 manual does not help. Can you please help me with that?
Samira
Message 14 of 16
(2,880 Views)
Hello Marco,
I've got the LMS100 working with the set of VIs that you have posted but I'm trying to figure something out.  There is a VI in the project to "find check mark" but I have no idea to what it is referring.  I.E.  What is a "check mark" in the context of LIDAR?  I've not, as of yet, been able to deduce the meaning from the code.
Thanks.
Message 15 of 16
(2,725 Views)
One short addition: the driver works also well for the LMS 5xx series: only keep in mind to set the correct scan resolution and frequency (modified the configuration VI to the LMS 5xx model): thank you so much, these VI's helped a lot!
Martijn
Message 16 of 16
(2,113 Views)
