Sine signal with alternating frequencies.
I am interested in generating a sine signal whose frequency and amplitude change after every cycle. For example: lets assume we have two amplitudes a1, a2 and frequencies f1 and f2.
I want a sine signal with a1, f1 and a2, f2 alternatingly. One sine pulse a1,f1 and other sine pulse a2,f2 and this pattern repeats.
Message 1 of 8
(3,180 Views)
Where are you having a problem?
There are functions on the waveform palette to allow you to build the different cycles of the sine wave.  Then you can append the two different periods of the two sine waves together to build it into one waveform.
Message 2 of 8
(3,178 Views)
Message 3 of 8
(3,174 Views)
Hi Preetham,
                     See the waveform palette,
                    Function pallete>>programming>>waveform
Thanks as kudos only:)
Message 4 of 8
(3,165 Views)
SrikrishnaNF
Srikrishna
Message 5 of 8
(3,150 Views)
Hello srikrishnaNF,
Thanks for the solution. But the issue is I just want to append one cycle of a1,f1 and one cycle of a2, f2. f1 and f2 could be DBL. Let me know if you have a solution. I shall appreciate it.
Message 6 of 8
(3,138 Views)
@Preetham1 wrote:
Hello srikrishnaNF,
I would make an array for your amplitudes and frequencies.  Use a FOR loop to create the waveforms and concatinate.
Message 7 of 8
(3,134 Views)
I just realized what you were asking for.  Sorry for the misinterpretation.  See if this works for you.
Message 8 of 8
(3,129 Views)
