Small Fonts missing from Icon editor selection
Hi all,
Recently had to do a new laptop, and just realized that I can no longer select Small Fonts within the icon editor.  It is installed fine, and in the main program, it appears on the font list.  But, if I open the icon editor, it is not available.
If I edit the INI file and set the font to Small Fonts, then I it seems to work, as long as I don't change the selection.
Any ideas?
Windows 10 Pro, LV2017 and LV2018 both show the problem.
Matthew
Message 1 of 16
(6,148 Views)
I also just realized that if Small Fonts was not the last font used within a specific icon, I don't seem to be able to get back to Small Fonts.
Message 2 of 16
(6,138 Views)
Panic time!  I just opened my Dell Laptop (Windows 10 x64, LabVIEW 2016, 2017, and 2018, 32-bit) and opened the Icon Editor.  On the Icon Text screen, the Font shows "Small Fonts" (Whew!).  Similarly, the Text Tools in Layers also shows Small Fonts.
Not sure why you are having this problem, but it doesn't seem (to me) to be Windows or LabVIEW's fault.
Message 3 of 16
(6,106 Views)
I see a few Google hits that might seem interesting.  (I Googled "labview icon editor no small fonts".)
What's maybe just as interesting is Bob replied to one of them.  😉  And no, not this one.  😄
Bill
CLD
(Mid-Level minion.)
Message 4 of 16
(6,092 Views)
Accepted by topic author Matthew_Kelton
Well, it appears to have been a Windows issue.  I still don't know why Small Fonts was available in the VI, but not the icon editor, but I got it working.
I downloaded the source code for the icon editor to try to get an idea of how it populated the list.  If I set the INI file variable, it actually used Small Fonts even if it wasn't on this list.  So, it was weird that it could access it, but not show it in the list.  So, the icon editor looks in the registry for the list of fonts.  Sure enough, that led to new Google searches which basically led me to believe that the font install was corrupted.
After fixing it, I probably could have fixed this myself within the registry now that I know the proper entries needed.  However, I didn't have access to another computer and wasn't sure that registry entries alone would fix it.
It should be noted as well that within Windows 10, the fonts showed up as installed if I browsed the C:\Windows\Fonts directory, but not show up if I looked at the Fonts Settings in the Control Panel.  Even after fixing it, Small Fonts still does not show up in the Fonts Control Panel Window.
So, I had to uninstall and reinstall the fonts, which was not trivial, as getting the font uninstalled would not delete the physical font file, and reinstalling, trying to overwrite the existing file would just result in the same original situation.  On Windows 10 at least, font files are owned by the TrustedInstaller, and even Administrators cannot delete the files.  Many sites state to just take ownership of the files, but Windows wouldn't even let me do that.
I finally found this - https://www.sevenforums.com/system-security/409760-solved-trustedinstaller-access-denied-permissions... - and the takeown and icacls commands finally got it to the point where I could delete the physical files and reinstall the fonts.  Once reinstalled, everything started working.
So, thank goodness NI provides the source for the icon editor, as I am not sure if I would have figured it out without very quickly.
Message 5 of 16
(6,086 Views)
Message 6 of 16
(5,834 Views)
This one should work (I just came from there):  Remove Trusted Installer as Owner.  Note that this is a somewhat dangerous thing to do, as you are messing with things that Microsoft really doesn't want you to mess with.  When you finish "messing", you should replace Trusted Installer as the owner -- a link contained in the link above describes how to do that.
Message 7 of 16
(5,805 Views)
Hello everyone!
I found a solution when the font "Small Fonts" is missing in the Icon Editor.
You just have to edit a line from the LabVIEW.ini file:
IconEditor.TextTab.TextFont="Small Fonts"
This allows you to apply this font, even if it does not appear on Icon Editor selection.
Pierre Perrin
Message 8 of 16
(4,069 Views)
I am running LabVIEW 2025 under Windows 11 Pro.  At first, Small Fonts was not installed on the PC and so did not appear in the list of available fonts in the icon editor.
I installed smaller.fon (provided above) and then could see the font in Windows via Settings and in the list of available fonts in the icon editor.  The problem is that, once selected, Small Fonts does not appear as I am used to it appearing in icons; rather, it looks like an anti-aliased color font instead of black-only pixels, not anti-aliased font.  I would appreciate some help in resolving this issue.  Thanks in advance!
Message 9 of 16
(777 Views)
Try the file listed here.  It seems to be solving the same problem you are seeing.
https://forums.ni.com/t5/LabVIEW/Small-Fonts-missing/td-p/3720897
Message 10 of 16
(767 Views)
