Sound Card Loopback
How do I control the line in-to-out loopback on a PC soundcard/Windows mixer?  Is there a .dll I can control with a library function?
(5,137 Views)
You probably need to use DirectSound, if it's possible. I'd look for a .net wrapper first if I had to use DirectSound.
(5,030 Views)
Programmatically Control the PC Volume in LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kHFKSA2&l=en-US
Does this answer your question?
(5,014 Views)
Hey thanks.  I didn't know which dll it was.  Still a bit of work to do researching the function etc.  What's the point of the for loops in your vi?
(5,000 Views)
Please mark the actual message that gave you the solution, not your "thank you" message.
(4,974 Views)
Accepted by grubworm
As far as I can tell. that example will only change the volume. It will not give you a loopback.
100X to get from x to 0, or from x to 100. As far as I can tell, you're basically pressing the volume button 100 times.
You can always acquire the sound from an input, and play it back to an output. In a while loop, that will give you a loopback, but there will be a latency. Using DirectSound the latency will be smaller, if it is in fact capable of doing it (I don't know).
(4,948 Views)
Thanks.  Yea I recreated it and got it to do mute or volume up.  I started reading some of the microsoft api docs but the info i'm looking for is buried deep.  It's a start, so...
(4,928 Views)
