Sound and vibration problem
Hi All:
     i met a problem when using sound and vibration toolkit,  when i select a sub vi from this toolkit panel , for example the "Filter"
vi , i can see very little parameter in the ico (SpxImage1.jpg ),but when a double click and enter the properties dialog box, i can see more options(SpxImage2.jpg) ,
what i want to know is, is there any way to set the detail sub vi parameters in the parent vi? because these parameters should be variables to my program
thanks
Message Edited by adobefree@gmail.com on 04-21-2009 03:20 AM
(2,991 Views)
Accepted by adobefree@gmail.com
Hi adobefree...,
right click on the express vi and select "open Frontpanel", you can now see the blockdiagram of the express vi. You can store it as a new vi and work with it. With the new vi, you have all controls from the dialog.
Mike
(2,975 Views)
