Sound bar project
Message 11 of 21
(1,362 Views)
@apok wrote:
Can you explaine me this please? i don't know how to use LabVIEW (and it's quite depressing).
Message 12 of 21
(1,359 Views)
takes your sampled signal amplitude (Y) and compares it to a certain amplitude level you set as a control. if signal is greater than user set amplitude, then ouput true...this can be connected to your flash led or beep.vi
Message 13 of 21
(1,350 Views)
@maria4 wrote:
Now I am confused.  I thought you mentioned you did several projects in LabVIEW?  This is pretty basic stuff...
Bill
CLD
(Mid-Level minion.)
Message 14 of 21
(1,348 Views)
@billko wrote:
No. As I mentioned above they gave us a task to build an easy project but they didn't teach us the software
Message 15 of 21
(1,341 Views)
@maria4 wrote:
As you mentioned in your first post, you said that you have "done many experiments in LabVIEW."  But I'm not here to argue that, though.  Here are some links that may help:
Learn LabVIEW
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
It's just that it would be very difficult to help you if you haven't even a basic understanding.
Bill
CLD
(Mid-Level minion.)
Message 16 of 21
(1,332 Views)
Go through the basics as provided previously.
Also, could you post your trials? Even if they're useless, maybe we can see where you are heading to the right direction or not.
We will be glad to help you!
billko
Spoiler
experiments that may have failed... I think that this is the point. 😄
Regards
Mondoni
Message 17 of 21
(1,317 Views)
One solution for your mic sensivity challenge:
Materials needed:
Shoe box (well what ever fit size)
Alarm clock (or whatever is on hand, not to pricy but create a constant buzzer sound)
Put buzzer and mic with fixed position in the box, and you have some sort of reference level.
Greetings from Germany
Henrik
LV since v3.1
Message 18 of 21
(1,299 Views)
billko
Spoiler
Regards
Thank you! It will be very helpful if you help me.
Attached is the project (yeah it not so good at all). I get the data from the mic and then I tried to find the wave components. Then to display the Max value of the amplitude (then I would like to add a led that will light on when the amplitude is higher then ..).
I wanted to say that I'm learning LabView but it's not so easy due to the fact that they didn't teach us nothing (and I'm not so good with computer...Smiley Frustrated)
Message 19 of 21
(1,273 Views)
billko
Spoiler
Regards
Hi, maria4:
I appreciate that you took the time to explain your situation to me better and I am very sorry we miscommunicated.  I'm not going to lie and tell you this will be easy.  I do highly recommend checking out the links I gave above so you can begin to understand the advice we are giving you.  I'll be more patient this time around.  🙂
Bill
CLD
(Mid-Level minion.)
Message 20 of 21
(1,262 Views)
