Sparse data interpolation [surface fit]
I've seen this problem before in the forums however, I'm still hitting a wall!
I have a set of sparse x, y, z data (see attached). I need to interpolate and populate a table with the interpolated valuesand finally get the surface plot. This topic was discussed in , http://forums.ni.com/ni/board/message?board.id=170&message.id=376161&query.id=73383#M376161 , but the VIs provided (also attached) would not work, could someone please tell me why. Other ways to attack this problem are also welcome.
Thanks!
(4,106 Views)
Hi cRIO,
Is the issue you receive an error or unexpected behavior from running these VIs, or that they are not providing you with a desired interpolation and surface plot?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(4,064 Views)
Did you ever solve this problem?
We are trying to do a 3d surface fit of a grid of sparse points and there is no built in vi in Labview that does this in one step.
Any solution?
Thanks.
(3,886 Views)
What have you tried already?  There is a Mathscript command called intrp2d_uneven (used to be called griddata) which does interpolation of unevenly spaced grid points.  Have a look here too.
If this doesn't work for you, I've found Kriging interpolation to give good results for many cases.
(3,871 Views)
