Specfifc IP Address configure control box
Dear RTSLVU,
Can you please explain the expression "[0-9]+[.][0-9]+[.][0-9]+[.][0-9]+" and how does its matching.
S Nagaraju
Message 11 of 18
(2,702 Views)
Hi Sonti,
I'm not that professional on RegEx, but I still can get the pattern:
- there are 4 blocks of numbers separated by dots
- each numeric block contains one or more digits
Looks like a regular IPv4 address… 😄
Message 12 of 18
(2,680 Views)
I use a string control but check it is valid using something like this.
Message 13 of 18
(2,670 Views)
@GerdW wrote:
Hi Sonti,
GerdW is correct!
WOW! You are a RegEx God.
=== Engineer Ambiguously ===
Message 14 of 18
(2,641 Views)
Dear all,
Thank you very much for your suggestions.
I have confusion about the expressions because I don’t have any software background.
Please any one explains about the expressions.
Thanks & Regards,
S Nagaraju
Message 15 of 18
(2,606 Views)
http://zone.ni.com/reference/en-XX/help/371361M-01/glang/match_pattern/
Read the bottom section on match pattern details
And http://zone.ni.com/reference/en-XX/help/371361M-01/glang/match_regular_expression/
Read the bottom section on match regular expression details
Message 16 of 18
(2,599 Views)
Thank you very much for yor support.
S Nagaraju
Message 17 of 18
(2,576 Views)
Thank you for your Inspiration. I found a simpler, not to say faster method:
Message 18 of 18
(1,849 Views)
