Spectral Measurement using NI SCOPE
Hey GerdW,
I have attached VI for V2019. I think it has something to do with axes. For 1kHz it gives 0Hz but for 1MHz peak is close to 0.1.
Message 11 of 13
(748 Views)
Hey Doug Thanks for the info,
Take a look at these, FFTs of 1KHz and 1MHz signals. X-Axis is looks messed up.
Message 12 of 13
(743 Views)
Accepted by Sahith24426
You can fix the x-axis of the FFT graph by setting the dt of the waveform from the x-increment of the cluster here:
From your screenshots (and this won't change even after fixing waveform dt ==> FFT df):
The peak for the 1 MHz signal is in the 1M * 4m + 1 = 4001 bin
The peak for the 1 kHz signal is in the 1k * 4m + 1 = 5 bin
You can zoom in on the 1 kHz FFT graph to verify that the peak is not at zero.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 13 of 13
(738 Views)
