Speed issue/ messy code
Here's what I have done so far... but I do have more questions.
1)Where can I find those "typedefed cluster" to bundle/unbundle? because anything I tried doesnt work
2)What's wrong with trying to get my matrix elements!?
Message 11 of 15
(1,191 Views)
There's nothing to find. You have to create a custom control that is a typedef. Please see the LabVIEW Help on how to create custom controls.
I'm sorry, but I don't understand this question. What are you referring to?
Message 12 of 15
(1,183 Views)
I took this screenshot out of coefficients.vi
The vi circled in purple is giving me a 4x4 matrix then with the vi circuled in green I ask for one element (which position is first row, first colum) of that matrix, and it works just fine. The problem is when I want any other element (as in the vi circled in red) it doesnt work.
As for the typedef, I'm gonna try to read more on that...thanks 🙂
tonh
Message 13 of 15
(1,180 Views)
Array indexing in LabVIEW starts at 0, not 1. So, if your green part is supposed to be the first row, first column, then those constants need to be both zero.
Note that the Index Array is expandable:
Also, the indexing values are automatically incremented, starting at 0. Thus, the following for a 1D array returns the elements in sequence.
You can read more in the LabVIEW Help.
Message Edited by smercurio_fc on 07-15-2008 04:18 PM
Message 14 of 15
(1,173 Views)
merci beaucoup!
tonh
Message 15 of 15
(1,148 Views)
