Speeding Up Load Array From Excel subVI
Hi there,
I've got a subVI that loads a 2D double array from an Excel file. Currently, it needs about 500ms between runs to not cause a variant error, something to do with getting everything opened and closed. I was wondering if anybody could see anything obvious that's slowing it down. If you could help me optimise this a little that would be great. Even if I could shave it down to 200ms.
(2,877 Views)
Sorry,
forgot to attach the subVi.
(2,876 Views)
What do you mean "between runs?".  Are you running this subVI multiple times?  If so, you should open the app reference outside the subvi and leave the reference open between runs (and don't quit Excel).
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,873 Views)
I pass an array of filenames into the subVI. It might contain 1, or it may contain 10. So I don't know whether or not I'll need to run it multiple times.
(2,870 Views)
Accepted by Chris Johnson
Here is a quick example of what I'm talking about.  Placing the App reference open/close outside the loop gets you down to around 300 ms.
(2,863 Views)
Hey, sorry to be a pain, for some reason I can't download that file, something to do with my network I'm sure. Any chance you could email it to me? chris84948@gmail.com
(2,855 Views)
That worked great. Now the total cycle time is down to about 300ms. I was worried that if everytime I added a new file to the array we would add 500ms, I would be taking 5-10 seconds on a larger recipe setup.
Thanks again.
(2,844 Views)
