Splitting large UFF58b files
I have been trying to open some UFF58b files in Signal Express.  Unfortunately with the larger files (300 - 500 MB)  the program crashes as soon as I try to review any of the waveforms.  The stored functions are short bursts of vibration data from 22 channels.  Is it possible to extract a set of 22 functions with the same timestamp using Signal Express?
Alternatively, what is the best way to extract a dataset using Labview?  I have been looking at the Data Storage VIs and can succesfully open the files with Open Data Storage (UFF58b).  Is it possible to set up a Query to select a particular Timestamp?
(3,480 Views)
Would you be able to attach a small UFF58b file as an example of the dataset you are working with? From what I understand you wish to extract a value from each function for the same moment in time?
Kind Regards,
(3,437 Views)
Hi
The attached UFF58 file shows one set of Time Waveforms for 22 sensors captured at the same time.
Please Note: I have renamed it as a txt file as uff is not recognised as a valid extension for an attachment.
The files I am working with contain 15000 - 18000 Time Waveforms (22 channels x 700 approx Time&Date (Record 3?))
Ideally, I would like to split the original file into 700 approx Time/Date files. This would allow me to view a block of all 22 channels relatively easily.
I don't need to extract sections of the Time Waveforms as they are only 2-3 seconds long and easily manageable.
Regards
Paul
(3,428 Views)
Accepted by M0z
Hi Paul,
Thanks for that. Please see this example which I just created to perform what you described. At present you can specify the Record 3 timestamp you are interested in and it will return those waveform functions.
I hope that helps.
Kind Regards,
(3,416 Views)
It works perfectly!
Many Thanks
(3,407 Views)
