Standard Report - Append Control Image Width Problem / Limitation or Bug?
Think about it !! There is a way. Here is a one...
You can put a Tab Control on the VI. Then put your elements in one tab. Put some other elements in other tab. Hide the tabs and also make the Tab Control transparent. Put two buttons "Next Page" and "Previous Page" Programmatically you can navigate the tabs with these to show the user what is going to Print.  Put a "Print" button too. When the print button is pressed. The 3 buttons become invisible and the code Switches the tab and prints  the Vi. It does this for all tabs, then makes  the buttons visible again. You can print multiple pages this way.
Even If I say so myself if you do this correctly, You have got a pretty good Print Preview and Printing Utility. I may do it even on some of my projects. Instead of using buttons you can also use the Menu Bar to the requisite function...
Good Luck!
Mache
Message 11 of 12
(1,084 Views)
if i need to work with html reports, i must have IE installed on the PC.
also i need to set the margins in IE >> Options
if i use standard report the image is not scaling/ fitting on the page. and NI has these problems on most of the labview versions, they didnt got time to fix it!!! 😞 😞
Kudos always welcome for helpful posts 🙂
Message 12 of 12
(817 Views)
