Stitch 2D Data
Can someone provide me idea how to stitch 2D images.
I have tried myself , but its not working.
Message 1 of 27
(6,211 Views)
I have a VI code to stitch images rows with more than one row.
There are some errors.
Can you help me to correct it.
Message 2 of 27
(6,045 Views)
Can you give some more background of what you want? I cannot see your VI since I'm on LV 2016. If you want to join 2 images vertically and you are using the VAS (vision acquisition software from NI), then you can convert both to arrays and build array. If you want to join horizontally you would have to transpose both, build the array, then transpose the output.
Message 3 of 27
(6,178 Views)
I want 3*3 array of images.
I don;t know how to give loops.
Because most of the blocks in labview support 1 row or column only
Message 4 of 27
(6,175 Views)
Maybe something like this will work for you. In the place marked "Load Images Here" you would load up your images from the file. Instead, I just create a ramp of values from 0 to 255. You might have to do some reorganizing to get the images exactly how you want them.
Message 5 of 27
(6,155 Views)
Thanks ...
Message 6 of 27
(6,144 Views)
I have a modified a  horizontal stitching program to vertical stiching. But I am not getting desired output.
Can you help me with it?
Message 7 of 27
(6,148 Views)
You have attached an empty diagram.
(Seems unnecessary waste of bandwidth because we can create that without your help in about a second. :D)
You should also link to the earlier discussion so we have context.
Message 8 of 27
(6,131 Views)
Sorry
Message 9 of 27
(6,113 Views)
What does "not getting desired output" mean?  You're not getting any output?  Or the output is different from what you expect?  And if so explain, in detail.
PS:  You should correct the spelling of "stitched" in your VI.
Message 10 of 27
(6,109 Views)
