Store analog (arduino) data in a 2D Matrix
I need to store analog data in a 2D Matrix. I cannot use 2 for loops, since I receive complete data after the completion of both loops. So I need to use 1 for loop and store my analogue data in a 8x8 Matrix in that loop. (One for loop so I can store data in run time and I dont have to wait till the end of for loop.)
if you any idea how I can achieve this please let me know.
(3,854 Views)
Look up RESHAPE ARRAY in the ARRAY palette.
Collect the data as a 1-D array, then reshape it into 8x8.
Steve Bird
Culverson.com
LinkedIn
(3,845 Views)
Accepted by maleee
OR
Initialize a 2-D array
integer divide the "i" of your loop by 8.
Use the remainder as the column index, and the quotient as the row index, and replace data at that R/C index with new data.
Steve Bird
Culverson.com
LinkedIn
(3,840 Views)
-OR
-Initialize a 2-D array
-integer divide the "i" of your loop by 8.
-Use the remainder as the column index, and the quotient as the row index, and replace data at that R/C index with new data.
For this, how will I store data? I mean I am getting serial data, how to store in a matrix? like the above logic you mentioned i.e. first store in array then convert it in matrix?
(3,835 Views)
Accepted by maleee
Create your 2-D array ahead of time, and populate it with zeroes, and feed it into a SHIFTREG on your loop boundary (from outside).
With each sample (inside the loop), divide the "i" of the loop by 8 and use the quotient and remainder as indexes into a REPLACE ARRAY SUBSET operation.
Steve Bird
Culverson.com
LinkedIn
(3,831 Views)
Thank you 😄
it worked XD
(3,815 Views)
