‎02-28-2014 03:55 AM
I am using the strain gauge vi for labview, on the myrio. I will be amplifying the voltage across the resistor of the strain gauge, due to the readings being so small. Do I need to document this on the program?
Caleb
‎02-28-2014 04:22 AM
‎02-28-2014 05:26 AM
Not really what I meant, obviously i'm going to document this, but as far as running the program, do I change any of the characterisitcs? I am still keeping the 3.3 input voltage, just amplifiying the strain gauge for better readings.
Caleb
‎02-28-2014 05:35 AM
‎06-03-2014 07:20 AM
Caleb,
I'm interested in measuring strain using a myRio. I wonder if you could offer advice on choosing strain gauges. For instance, which strain gauges did you use?
Thanks in advance,
Eric
‎06-04-2014
12:51 PM
- last edited on
‎08-20-2024
05:23 PM
by
Content Cleaner
Hi EricReynolds,
The article below offers some guidance on choosing a strain guage:
‎07-22-2014 12:30 PM
How do you use a strain gauge with the myRIO?
‎07-23-2014
09:40 AM
- last edited on
‎08-20-2024
05:24 PM
by
Content Cleaner
Hey,
Here is a guide to some common myRIO projects: https://education.ni.com/teach/resources/92/ni-myrio-project-essentials-guide
However, since this is an older thread on a slightly different topic, if you want to receive good help you should start a new thread.
‎07-23-2014 05:41 PM
Thank you, Catherine; this was helpful.
I ended up using general purpose linear pattern strain gauges from Vishay Precision Group, M-Bond 200 adhesive (to steel) and AD620 amplifiers.
