Strain gauge
I am using the strain gauge vi for labview, on the myrio.  I will be amplifying the voltage across the resistor of the strain gauge, due to the readings being so small.   Do I need to document this on the program?
Caleb
Message 1 of 9
(5,308 Views)
Hi caleb,
documenting what your software does is never wrong.
The same applies to any hardware that is used for a certain experiment…
Message 2 of 9
(5,297 Views)
Not really what I meant, obviously i'm going to document this, but as far as running the program, do I change any of the characterisitcs?  I am still keeping the 3.3 input voltage, just amplifiying the strain gauge for better readings.
Caleb
Message 3 of 9
(5,284 Views)
Hi Caleb,
amplifying always amplifies any noise, so you may need to handle that…
Message 4 of 9
(5,281 Views)
Caleb,
I'm interested in measuring strain using a myRio.  I wonder if you could offer advice on choosing strain gauges.  For instance, which strain gauges did you use?
Thanks in advance,
 Eric
Message 5 of 9
(5,179 Views)
Hi EricReynolds,
The article below offers some guidance on choosing a strain guage:
https://www.ni.com/en/shop/data-acquisition/sensor-fundamentals/measuring-strain-with-strain-gages.h...
Catherine B.
Message 6 of 9
(5,152 Views)
How do you use a strain gauge with the myRIO?
Message 7 of 9
(5,072 Views)
Hey,
Here is a guide to some common myRIO projects:  https://education.ni.com/teach/resources/92/ni-myrio-project-essentials-guide
However, since this is an older thread on a slightly different topic, if you want to receive good help you should start a new thread.
Britton C.
Senior Software Engineer
Message 8 of 9
(5,044 Views)
Thank you, Catherine; this was helpful.
I ended up using general purpose linear pattern strain gauges from Vishay Precision Group, M-Bond 200 adhesive (to steel) and AD620 amplifiers.
Message 9 of 9
(5,025 Views)
