Strictly Type Constant Refnum
It's easy enough to create a Refnum control for a strictly typed cluster control.
I want to create one for a strictly typed cluster constant.
Is that even possible?
Message 1 of 23
(3,796 Views)
Yes.  It's possible.
Just enumerate all objects on the diagram, and find the one with classname as clusterconstant.
George Zou
Message 2 of 23
(3,786 Views)
but ... why?
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 23
(3,765 Views)
@zou wrote:
Yes.  It's possible.
That's not even close to what I asked for.  I want to set the server class of a refnum control to a strictly typedef'd cluster constant.
Message 4 of 23
(3,739 Views)
@Yamaeda wrote:
but ... why?
For the "Affected Items" typedef for a custom shortcut menu.
Message 5 of 23
(3,737 Views)
Not sure what you mean.
Are your try to something like this:
Could you should us your code?
George Zou
Message 6 of 23
(3,696 Views)
Are you only reading every 5th word that I write?
I want a Refnum Control to have a VI Server Class of a strict cluster type.
Message 7 of 23
(3,685 Views)
It might not be possible, since having a strictly typed constant is only enabled by a special flag (which I believe you are intimately aware of).  I don't believe you can even make a reference for ANY kind of BD constant.
But I guess that's why you're asking, because you know all of this and you want to see if anyone has some kind of undocumented way to make this happen.
Edit: What is to be gained by using a BD constant ref instead of a control ref?  I don't see any practical reason why a control couldn't be substituted for a BD constant.
Bill
CLD
(Mid-Level minion.)
Message 8 of 23
(3,670 Views)
I think you need to give zou a break, as this user is usually spot on with their answer when they chime in.
Bill
CLD
(Mid-Level minion.)
Message 9 of 23
(3,667 Views)
You can make a reference to a BD constant:
But I want the reference to be for a specific type of cluster, not a generic cluster.
I want this for the "Affected Items" typedef for a custom shortcut menu.
Message 10 of 23
(3,656 Views)
