Strictly Type Constant Refnum
I'm going to say that NI hadn't thought through all the consequences of enabling strictly typed constants and doesn't show "Include Data Type" for constant references of any type.  I don't know if strictly typed constants are officially supported, so I don't know whether this should be considered a bug or not.
Bill
CLD
(Mid-Level minion.)
Message 11 of 23
(2,276 Views)
@billko wrote:
It might not be possible, since having a strictly typed constant is only enabled by a special flag
Which flag are you talking about ?
The closest I know is "EnableStrictTypedefConstantConfiguration", but this is about typedef'd constants on the diagram, which is different from strictly-typed constant refnums.
Out of curiosity, I have tried to merge the type code of a strictly-typed control refnum with the type code of a generic constant refnum, then using "Flattened String To Variant" and "VI.Create from Data Type" to create a chimaera data type that would hypothetically be a strictly-typed constant refnum, but without success. The additional type info added to the constant refnum is simply ignored =(
So sadly I think it is not possible
I guess you want to set the class of the Affected Items of your plugin to a specific strictly-typed constant to avoid further filtering on the data type ? Is it a matter of performance for the plugin ?
Message 12 of 23
(2,240 Views)
I have to admit I was pretty confused about what we were talking about.
Bill
CLD
(Mid-Level minion.)
Message 13 of 23
(2,223 Views)
You have a lot more options under "GObject" than I do in my LabVIEW installation. Are you using an LabVIEW ini key?
@paul_cardinale wrote:
Message 14 of 23
(2,209 Views)
I'm assuming you're using the SuperSecretStuff-key or something, since i don't have constants as a reference option.
However, it seems you can drop a .ctl in a static VI ref and type cast a GObject ref that way. Would that work?
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 23
(2,187 Views)
What I see is:
 - VI Scripting ON to access scripting classes (light blue nodes) like Constants and other diagram objects + additional scripting methods and properties on "normal" classes.
 - INI Key "SuperSecretPrivateSpecialStuff=True" to access private classes (brown nodes) like Provider, LVTarget, CopyExpert, ... but these are hardly useful even for advanced scripting. If you add this INI key you will have cluttered menus for additional functions that might be useful only 0,0001% of the time.
Message 16 of 23
(2,183 Views)
It's easy enough to create a Refnum control for a strictly typed cluster control.
I want to create one for a strictly typed cluster constant.
Is that even possible?
I'm also not entirely sure what you want or how to test if it works.
Anyway, if creating a control is easy, creating a constant from it might work:
This:
Turns the strict (cluster) control reference to a strict (cluster) constant:
Both are references to a specific cluster:
If that isn't what you're looking for, I'd need some code for illustration...
Is this something you can create manually (as an example)?
Message 17 of 23
(2,172 Views)
"Creating a strictly-typed control refnum constant" is different from "Creating a strictly-typed constant refnum control".
In the first case the data type is a refnum of the Control class, in the second case the data type is a refnum of the Constant class.
Then you can effectively make a control or a constant out of these 2 data types, but this is not what it's about.
We are talking about an hypothetic strictly-typed constant refnum data type, which mimics the strictly-typed control refnum data type.
You cannot create this manually because it surely does not exist at all...
Message 18 of 23
(2,154 Views)
That actually helped.
Would have been a good first reply...
I hope you all see that this isn't that obvious.
Message 19 of 23
(2,144 Views)
I agree.
It's Sisyphean, at least in current LV versions.
Message 20 of 23
(2,117 Views)
