Strictly Type Constant Refnum
@raphschru wrote:
@billko wrote:
It might not be possible, since having a strictly typed constant is only enabled by a special flag
Which flag are you talking about ?
The closest I know is "EnableStrictTypedefConstantConfiguration", but this is about typedef'd constants on the diagram, which is different from strictly-typed constant refnums.
Out of curiosity, I have tried to merge the type code of a strictly-typed control refnum with the type code of a generic constant refnum, then using "Flattened String To Variant" and "VI.Create from Data Type" to create a chimaera data type that would hypothetically be a strictly-typed constant refnum, but without success. The additional type info added to the constant refnum is simply ignored =(
So sadly I think it is not possible
I guess you want to set the class of the Affected Items of your plugin to a specific strictly-typed constant to avoid further filtering on the data type ? Is it a matter of performance for the plugin ?
I was wanting to do it just for cleaner block diagrams.
Message 21 of 23
(762 Views)
@pauldavey wrote:
You have a lot more options under "GObject" than I do in my LabVIEW installation. Are you using an LabVIEW ini key?
@paul_cardinale wrote:
I turn on lots of stuff:
LVdebugKeys=True
UseUnicode="True"
showSystemVIs="True"
EnableStrictTypedefConstantConfiguration="True"
AdvancedPlotLegendMenu="True"
enableSecretPopups="True"
ActiveXMoreContainerOptions="True"
XNodeDevelopment_LabVIEWInternalTag="True"
XNodesDebugging="True"
XNodesEnabled="True"
XNodeWizardMenu="True"
XNodeWizardMode="True"
XTraceXNode="True"
XNodeDebugWindow="True"
SuperPrivateScriptingFeatureVisible="True"
SuperPrivateSpecialStuff="True"
SuperSecretPrivateSpecialStuff="True"
SuperSecretListboxStuff="True"
SuperSecretCLAFeatures="True"
Message 22 of 23
(759 Views)
Nothing wrong with that.
Message 23 of 23
(726 Views)
