String Costant Invoke Node
Hello everyone, i am new user and a beginner in Labview programming.
I've created a VI to ping device in ethernet lan (of which i enclose a photo). The VI simply shows a green led if the ping "pong".
I would like to use the same Invoke Node with an array of string costant, i can't do it.
Thank you very much.
(3,891 Views)
Accepted by nellooo
Hi nellooo,
here comes "autoindexing" and "FOR loops" into play!
Use a FOR loop to autoindex over your string input array. (And you probably want an array of string controls, not an array of string constants.)
As this is quite basic I suggest to go through those free online courses offered by NI!
(3,882 Views)
Thanks for feed.
Maybe you have not understand what i need.
In the attached file, would like have a single constructor, invoked and property node, a single comparison and three LED.
(3,866 Views)
I think I understood very well.
Again: you need a FOR loop that autoindexes your array of IP addresses. Take the basics courses!
(3,859 Views)
@nellooo wrote:
Thanks for feed.
[GerdW answered while I was typing...]
Actually, GerdW answered your question quite well, with exactly the solution (I believe) that many other senior programmers on this forum would have used. Perhaps you don't understand how to use LabVIEW very well, or how to get to the free tutorials he recommended. A couple of the free online tutorials he referred to are listed at the end of this message, there are others. The LabVIEW Help screens are also very good references on specific topics.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(3,843 Views)
