String indicator vertical scroll-bar BUG?
Agreed! This bug is so annoying and the "solution" of coloring the string the same as your background does not work a lot of times when trying to make a fancy UI, like if the background is a slight gradient.
Please fix it NI!
Message 11 of 13
(1,148 Views)
Here's a real workaround:
You can (tested) also put the method in a callback even, if you don't want to add complexity to your main vi.
Message 12 of 13
(1,105 Views)
Just to close this off - this bug is fixed in LabVIEW 2020 (so I understand).
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 13 of 13
(1,056 Views)
