Strings too long
Well... now I did separate the NI IO TRACE line where i send the "long string" and as you can see (in the --- line) thats where the break goes
exactly at 190 characters... i don't know what this means or how can i fix it tho... 😞
Message 11 of 30
(2,608 Views)
Can you show as the part of the LabVIEW code where you write your string?
And I still don't understand how you determine that the writing stops after 190 characters...
Regards, Jens
Kudos are welcome...
Message 12 of 30
(2,604 Views)
Under...
Isntrument IO >>> VISA >>> VISA Advance >>> Bus Specific
you will find "VISA Set I/O Buffer Size".
Read about the mask since it will determine if the settings is applied to transmit or receive.
Also..
Have you checked your flow control settings?
Your widget may be getting overwhelmed and assert XOff to throttle the incoming stream of data.
Ben
Message 13 of 30
(2,599 Views)
Regards, Jens
I know because i can count where the machine stops and where that screenshot shows:
G91
G1 X200 Z40 Y300
; G
G1 Y-20
G1 Z5
G1 Y20
G1 X50
G1 Y-20
G1 X-25
G1 Y10
G1 Z-5
G1 X25 Y-13
G1 Z5
; X
G1 X-50
G1 Y-20
G1 X25
G1 Y20
G1 Y-25 X25
G1 Z-5
G1 Y-3
G1 Z5
; A
G1 X-50
G1 Y-2 (Exactly 190 chars)
Message 14 of 30
(2,587 Views)
Is G.G1 Y-2 a valid command syntax?
-AK2DM
Message 15 of 30
(2,580 Views)
the g. its not
g1 y-2 should be g1 y-20 but thats where is cutted
Message 16 of 30
(2,576 Views)
I take it you have some LabVIEW code that is doing this.  Make a copy of the VI(s) that contain the VISA routines -- call it ForumVI.vi.  Now open this VI, throw away almost everything except the VISA routines, including the VISA Open, VISA Read, VISA Close, and any other VISA commands.  You can leave in anything wired to the VISA routines.
When you have a nice, compact VI that has only your VISA Stuff, attach that VI to your Reply.
You are almost certainly doing something wrong in your VISA Read or VISA Setup (or maybe your Arduino is at fault).  However, without seeing what you are doing, we're "making guesses" at best, you say "No, you guessed wrong", and everyone's time is being wasted.
Bob "Attach Your Code" Schor
Message 17 of 30
(2,561 Views)
ill do that, sorry for the troubles, i thought that maybe was a very known issue, ill do it in a few hours, im heading home now, thanks
Message 18 of 30
(2,555 Views)
Please note the label on that string indicator;
Buffer Contents (Abbreviated)
I believe it is tell you that it is not showing you the entire write buffer. Check your setting in NI IO Trace to make sure you are not chasing a red Herring.
Ben
Message 19 of 30
(2,553 Views)
Actually that screenshot shows the Write buffer contains 473 characters (ending in (\codes) "Z-5\nG28\n" .  the "----" is there as a placeholder for the undisplayed portion.
What do you need corrected?
115200 is unattainable at clock speeds below 3MHz on most arduinos is there a DOR error?
Message 20 of 30
(2,546 Views)
