Strip Chart Scrolling Problem
The data coming from a simulated DAQ is behaving as it always has for me.
To play around with frequency, you can use the 'Simulate Signal' express VI.  I attached a VI doing this (saved in LV2011).  The same behavior persists.  Hopefully NI is now aware of this.
Message 11 of 18
(2,167 Views)
Hi Joe,
Thank you for highlighting this behaviour in LabVIEW 2012. I can confirm that I see this behaviour in 2012 and not in 2011 so I will be filing a Corrective Action Request to take the problem to R&D so that they can assess how they are going to fix it.
As a temporary workaround you could possibly use the property node "defer panel updates" to force when the front panel updates as this will refresh the chart and stop the elongation. It is worth noting that the data produced (although looks wrong in the chart) is the correct data.
Thanks again.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
Message 12 of 18
(2,153 Views)
Hi Larry,
I just wanted to followup and see if there is an update to the Corrective Action Request? Thanks.
-Joe
Message 13 of 18
(2,130 Views)
This was reported to R&D (CAR # 380245) for further investigation.  It is still under investigation.
Dave
Dave C.
Message 14 of 18
(2,116 Views)
Has anyone found a workaround for this?  A client needs to review live data, and the timing is important.  The only solution I've found is to compile to a LV2011 executable (not optimal).  Thanks.
-Joe
Message 15 of 18
(2,097 Views)
Is this only with simulated DAQ I/O??? Please say yes. I just upgraded my project to LV2012.
Message 16 of 18
(2,088 Views)
Sorry, but no. It is with any data written to a chart.
Message 17 of 18
(2,085 Views)
Hi Joe,
I just checked the status of the corrective action request.  It is still being researched.  Unfortunately, no viable workarounds have been identified to date.
Dave C.
Message 18 of 18
(2,066 Views)
