SubVI is missing
Or put it in the directory of the project. Just select it when the vi is searching for the subvi.
Message 11 of 17
(1,252 Views)
Sorry I did not read you first post I will try this solution at my first opportunity thank you very much for your help!
Message 12 of 17
(1,250 Views)
I have version 6.1 so i beleve the file you gave me should work. Can you please advise me before I attempt this.
Message 13 of 17
(1,245 Views)
Just back everything up first, of course. Just try it and see. Should not ahrm your progam until you resave it.
Message 14 of 17
(1,243 Views)
THIS WORKED
SOLUTION
C:\Programs Files\National Instruments\LabVIEW 6.1\vi.lib\Utility\file.llb     did not exist. I used the file ErnieH posted earlier in the forum (file.llb)  and place it in the C:\Programs Files\National Instruments\LabVIEW 6.1\vi.lib\Utility directory. After doing this, I restarted my LabVIEW program and did not get the error "SubVI is missing ......"
Thank you again for all your help ErnieH!
Message 15 of 17
(1,238 Views)
At some point, you may want to investigate how that LLB came to be missing...it is a core file that is installed with LabVIEW.  If that one is missing, then other core parts of LabVIEW may be missing too. I recommend repairing your LabVIEW installation when you get a chance.
Message 16 of 17
(1,232 Views)
Glad I could help. You can run into a lot of strange things on old programs.
Message 17 of 17
(1,217 Views)
