Subtracting 2d arrays into 1d array
Hi everyone,
So I'm having a different issue now with subtracting 2d arrays into 1d array.  I'd like to subtract each row and output the result as a 1d array.  Anyone have any ideas?  I'd tried to look elsewhere but the info online doesn't seem to work for me.  Such as:
http://forums.ni.com/t5/LabVIEW/Subtract-2D-array-elements-and-insert-the-result-into-a-new-row/td-p...
I'm only interesting in outputing the result as a 1d array and do not care about keeping the original 2d array.  For example:
2D array:
1  2
5  2
6  4
Result:
-1
3
2
Thanks!
Jon
Message 1 of 12
(5,937 Views)
Use a FOR loop to get each row of the 2D array. Subtract the elements.
Show what you have done with a VI.
Message 2 of 12
(5,934 Views)
Hey nyc,
I've already put it into a for loop but I get the a total of two cell result where instead I should be getting much more than that depending on the sample points taken.  I've attached what I've tried to do but obviously it's wrong.  thanks.
Jon
Message 3 of 12
(5,925 Views)
Here's the image.
Message 4 of 12
(5,924 Views)
Indexing array and then subtractiong the rows is the easiest way.
Kudos are (always) welcome for the good post. 🙂
Message 5 of 12
(5,922 Views)
Close, but you need to index out the colums.
Message 6 of 12
(5,913 Views)
Thanks Odessy27,
I've tried using this index array before with index(row) and index(column) but for some reason my 2011 labview doesn't recognize this and automatically changes it to index without the 'row' and 'column' info.  I've even tried to copy and paste it onto my labview and changes it back once I connect the lines.  It's definitely a 2d array so I don't know what I'm not doing right.  I'm sure I've overlooked something but not sure how I can tell the index array only to subtract from the rows.  Thanks.
Jon
Message 7 of 12
(5,908 Views)
Accepted by JonRod
Are you indexing the 2D array itself or are you indexing inside a for loop with autoindexing?
Message 8 of 12
(5,897 Views)
Hi again Crossrulz,
I'm indexing it inside a for loop and iterating it depending on the number of elements.  Here's the image.
Message 9 of 12
(5,891 Views)
Sorry for the unconnected wire from the iteration from the index array but it's supposed to be wired.
Message 10 of 12
(5,890 Views)
