‎04-17-2008 12:54 PM
‎04-18-2008 02:13 PM
‎04-18-2008 02:42 PM
‎08-24-2009 09:58 AM
I have the same basic problem as Jeanius.
I built a reflectance spectrometer and have some opensource software that generates a spectrograph from the input signal, in this case simply a photo of the spectrum. The opensource software outputs an array of wavelength vs peak height values. However, the x-axis (wavelength) cannot be fixed, but instead depends on a manual selection of the spectrum range. The result is that the reference spectrograph has x-values that are different from the sample spectrograph.
Please see http://holeman.org/spectra/rose%20spectroscopy.html for a more complete description of the application.
I need to be able to subtract the sample spectrograph from the illumination source spectrograph in order to generate a sample reflectance spectrograph. I can pad the arrays to match up the number of data points between the sample and reference arrays but this does not solve my problem because the x-values are are still different and so the y-values cannot be subtracted directly.
Is it possible with Labview to subtract one graph from the other? It guess that is to say, is there any interpolation function that will generate reasonably valid matching x-values from the raw data?
‎08-25-2009 06:02 PM
‎08-25-2009 07:16 PM
Thanks Chris, that was my first thought as well. I can script that myself in vb or php but I was hoping to find something ready-made and thought Labview might have some curve arithmetic built in.
‎05-26-2010 03:11 PM
I have a very similar problem. I first measured the background noise from my accelerometers and did FFT on that data. I then measure the accelerations during a "real" test and subtract the background data from the "real" data, my problem is the frequency peaks are not perfectly lined up so the noise is not subtacted properly. I am using the align and resample express VI to get the same t0 and dt on the baseline and "real" data. Any ideas on how to ensure the peaks align properly?
Jacob
‎05-26-2010 11:57 PM - edited ‎05-26-2010 11:58 PM
How close is your noise frequency spectrum to your signal spectrum?
Could you use your FT peak(s) as input(s) to a time domain band pass filter on your target signal?
‎05-27-2010 07:24 AM
Jacob,
If you run the background acquisition several times, how reproducible is the result? If it is not very reproducible, baseline subtraction will not work.
What is different about your mechanical system when you run the baseline compared to running the real test? Is the device which excites the system present in both cases? Are there things which could change the mechanical resonances during the real test? Anything like this could change the transfer function of the system enough to invalidate the background.
Tell us more about what you are doing, please.
Lynn
‎05-27-2010 03:59 PM
The system is definitely different when testing compared to when checking background noise. This is a friction tester and when I collect data with out the friction samples in contact I get vibration signals. These signals show up again during the actual testing and I would like to subtract this "system noise" from the test data. I understand there will be a frequency shift since the damping, stiffness, geometry is different between the two.
Jacob
