Subversion .svn folders are auto populated
I've a problem with my project explorer. On one computer my project shows all .svn folders which are normally hidden. Because I'm working with autopopulating folders my project dependencies aren't clear because of the duplicate entries in the .svn folders.
I've attached a screenshot of my project explorer.
Joachim
(3,508 Views)
Accepted by Joachim082
Hi there
I can confirm this for
- LabVIEW 8.5.1 and .svn - folder NOT hidden
I have no problems with
- LabVIEW 8.6.1f1, .svn - folder hidden or not hidden
Are you sure the .svn folders are really hidden?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,496 Views)
I believe this was changed in LV 2009, so I suggest you look through the upgrade notes.
Personally, I don't use auto-pop folders, so I don't have this problem. I think that you get a better experience if you only put the files you want easy access to into the project. The rest will be there as dependencies and you can see the disk hierarchy in the Files tab.
___________________
Try to take over the world!
(3,494 Views)
Hi tst,
I am currently working with LV2009.  My problem was that only some folders are hidden on the file system. Now I changed it recursive to hidden and everything works fine.
Thanks for your response.
Joachim
(3,488 Views)
