System.BadImage.FormatException
Hello All
I typically use C# with Measurement studio to create class libraries that can be called from LabVIEW using .NET constructors. Recently I uninstalled LabVIEW and reinstalled it. Ever since, I've not been able to call any .NET DLL in LabVIEW.
I use .NET 4.0, LabVIEW 2011 sp1, Visual Studio 2010. I've attached a copy of the error I get.
Any help would be appreciated.
(3,842 Views)
Accepted by winterishere8
Hi Spartan00,
I have found another forum post that has someone getting the same error as you. Try the mentioned steps in the replies and see if you can fix that error.
http://forums.ni.com/t5/LabVIEW/NET-DLL-System-BadImageFormatException/m-p/1831403#M626820
DylanC
(3,826 Views)
Yes there was a typo in my config file. NI application engineer helped solve the issue. Thank you.
(3,822 Views)
