TCP Communication with XBee Wifi from LabVIEW VI
Hi all,
Currently I am working labVIEW program to connect to XBee Wifi module.
As I just want to send a character "1" to my wifi Module, XBee S6B . So I just make a vi (Attached below)  that's similar to example by using TCP connect to my XBee, however, the TCP listen couldn't connect to my XBee.
Indeed when I use hyperterminal in my computer ( by inserting IP address and Port of Xbee) to send character "1" to Xbee , Xbee successfully detected 1.
Please advised me for my vi.
Thanks in advanced.
Message 11 of 12
(831 Views)
Are you getting an error code at the TCP listen? What happens when you run the program?
-Jayk
RF R&D
Message 12 of 12
(804 Views)
