TCP/IP Server-Client error
Hi everybody,
I'm studying about TCP / IP and make an example but it is not yet operational. Therefore I'm looking forward to receiving the help.
Fig.1: Server
Fig.1: Client
Message 1 of 11
(5,774 Views)
What is the problem you are facing? Establishing the communication or recieving the data and formatting it back?
Message 2 of 11
(5,766 Views)
Message 3 of 11
(5,761 Views)
Copy the server Boolean cluster and paste it in the client where you are passing the "string constant". Also don't define the size of 2 bytes, you may endup missing data. From the server first send the size of the data to the client and then send the actual data.
Message 4 of 11
(5,757 Views)
I've changed to this but not been. help me, pleasesua lai.jpgfront panel.jpg
Message 5 of 11
(5,724 Views)
Thanks for all answer.
Sorry, I'm not understand.
Message 6 of 11
(5,691 Views)
Create a cluster constant(check in the cluster palette) and then take 2 numeric DBL constant and select them and drag them into the cluster constant. Then Take two false constant pull those guys as well into the cluster constant. Right click the cluster constant and go to the Auto sizing and select arrange vertically. Are you getting what you expected? Please go to my profile (click my name not the kudos) and go to Tags there you can find LV basic, click that you will find LabVIEW basic materials, please go through them (I am not able to give you the link, since posting from mobile).
Message 7 of 11
(5,681 Views)
It's clear that you looked at the shipping examples but it's also clear that you did not understand them. The whole purpose of reading two bytes and using that got the next read is that the example is pretending (with 2 bytes), the size of the data being sent. Your server does not do that so your read will fail.
It also does not make any sense to create a cluster with four elements. The cluster you have only had two elements. Focus on fixing the server.
Message 8 of 11
(5,666 Views)
Thank ,
Can you tell me what is the name of this function? I want to make a example to understand more about its nature.
Message 9 of 11
(5,649 Views)
Its string length function which is used to find the length of the string. If you want to know the name and its working select the function and press ctrl-H you will get the context help. You also have the detailed help also along with examples. Please go through the basic materials and also read help files so that you can learn by yourself.
Message 10 of 11
(5,637 Views)
